I took these pics of a Bell B25D that is working on a sea defence near me. I've never seen a setup like this before, I've only see the driveshaft go straight into the diff lock housing. Is Bell the only ADT that has a break om the shaft, don't like the idea of that with all the sand around.
Bell B25D close up pics of drive shaft
Topic author - Posts: 467
- Real name: Geraint Jones
- Has thanked: 5 times
- Been thanked: 6 times
Re: Bell B25D close up pics of drive shaft
Ye, we had one on the pipeline and it stalled going up a 6 inch step. More driver error I think.
- Real name: john smith
had two on hire from hydrex 2xbuckets off a cat 365 and they could just about pull off the two cat d400 was running s round thenm alday long
they only look good thats all
- Real name: Stu Bickley
- Has thanked: 70 times
- Been thanked: 116 times
Park brake on Drive shaft is a common occurance, they are normally high enough out the way to avoid all the crap and poop that gets thrown oop.
Its a wee transfer gear on the diff input, not sure who'se axles they are running at the moment, use to be ZF then changed to Bell'sown axles.
SB
SB
- Real name: Ross
- Been thanked: 27 times
Yeah, Volvo Use a Driveline P brake, Spring Chamber, Air release and Spring applied. The Newer A40E's use brake packs.
The D350 and D400E's use a Park brake like that except the CAT design was rubbish, CAT use Hydraulic release.
The Diff looks like it has a Reduction.
