i must be doing the slowest rebuild ever on a dumper,(winget 3S) any advise on kingpins ?? where can i buy some. has anyone actually changed/ replaced them?
or do we just have wobbly wheels any advice would be much appreciated
Ian
winget 3s king pins
- Has thanked: 1875 times
Re: winget 3s king pins
I would have thought that these components are still available new off the shelf? If not strip it down, measure how much wear you have , get a local engineering shop to knock you up a couple of new pins and bushes, I guess that would be a reasonable solution.
- Real name: norman orrick
- Has thanked: 144 times
- Been thanked: 132 times
Fess28 wrote:i must be doing the slowest rebuild ever on a dumper,(winget 3S) any advise on kingpins ?? where can i buy some. has anyone actually changed/ replaced them?
Ian
The Winget 4s I have has been on going for 10 year, you are not alone.
Norm.
- Has thanked: 302 times
All restorations take time to complete. You have to consider the cost factor, parts availablity (it took me 6 years to find a special part for an old crude oil engine I did up) plus your time to have to do it.
I have an endless supply of toys to rebuild from stationary engines to vintage lawn mowers so Im just cruising with them as I can.
Kingpins can be a pain. You can buy replacements online or at a parts store. Changing them is doable but can be tricky.
When doing king pin replacements the bushes are close to the correct size but when pressed into place become tight and they must be reamed to size plus clearance for the new pin to fit.
Topic author - Posts: 16
- Real name: Ian
- Has thanked: 12 times
- Been thanked: 3 times
Thanks, got them sorted now! Winget had the parts! All reamer out and fitted. Yes they are a pain to reamer out and keep them parallel to each other! Thanks for the helpful replys
So glad its sorted n thanks for letting us know. This is how Forums are suppose to work. Members helping each other.
