Fuel injector pipe leak
Discuss dumpers here
weirdfish
Been thanked: 1 time
Post #1 by weirdfish » Tue Sep 12, 2023 1:29 pm
weirdfish
Re: Fuel injector pipe leak
Post #2 by weirdfish » Wed Sep 13, 2023 1:47 pm
I’ve got 2 injector pipe leaks, it appears to be coming from above the top but, ( lister petter 3 cyl engine ).
I’ve taken the top cover off and this is what you can see, ( hopefully in pic ).
How do I remove what’s here to get to where the pipe joins on.
If no pic appears please click on link above
cobbadog
Real name: John
Has thanked: 302 times
Been thanked: 138 times
Post #3 by cobbadog » Thu Sep 14, 2023 1:33 pm
WOW, is the connection down inside there somewhere?
If so its a shitty idea. Have you been able to Google search a workshop manual yet?
Gunna be a lot of fun to get to that part. Are you ale to get a spanner on the nut to see if it is loose or not?
weirdfish
Post #4 by weirdfish » Thu Sep 14, 2023 2:05 pm
Not gone any further yet, trying to work out if I have to remove the complete head or not to get to it.
weirdfish
Post #5 by weirdfish » Fri Sep 15, 2023 11:42 am
Looking at a manual I found online it says about using a slide hammer to remove the injector, is that ever right?
If so where do you get the correct fitting for the slide hammer.
Has thanked: 1873 times
Been thanked: 1692 times
Post #6 by Jeremy Rowland » Fri Sep 15, 2023 8:34 pm
weirdfish wrote:Looking at a manual I found online it says about using a slide hammer to remove the injector, is that ever right?
I would say the answer is yes you would require a slide hammer, use the injector pipe to identify the thread and buy a connector of the same thread then weld it to a piece of metal that will fasten to your slide hammer. :thumbup:
Return to “Dumpers”
Users browsing this forum: No registered users and 65 guests
