Anyone who knows what type of engine this is?
Type plate is gone..
What Lister engine is this
- Has thanked: 1887 times
- Been thanked: 1701 times
Re: What Lister engine is this
Hi and welcome I'm sure somebody on here can point you in the right direction.
essexpete wrote:http://www.realdiesels.co.uk/listeridentification.html
Any help?
Nope, have seen this but could not find any that looks like mine, but also i could miss something..
My hope was that someone would recognize the engine Type and have some clue here in the forum.
- Real name: Jörg
- Has thanked: 10 times
- Been thanked: 182 times
Thanks, looks right but the LD1 and SL1 also seems right.
Is there only a rivet ID plate on the engine or could it be stamped on the block also?
Hard to say what engine when more models look the same
- Real name: Neil Milward
- Has thanked: 158 times
- Been thanked: 50 times
Are there any numbers on the identification plate attached to the injection pump and the injector that may help? I think they would be more likely to be Bryce rather than Lister numbers? You may be able to cross refer these back to the engine type that way via a stockist of Lister parts or though the internet.
I hope this helps.
Neil. (v1230nm)
I hope this helps.
Neil. (v1230nm)
v1230nm wrote:Are there any numbers on the identification plate attached to the injection pump and the injector that may help? I think they would be more likely to be Bryce rather than Lister numbers? You may be able to cross refer these back to the engine type that way via a stockist of Lister parts or though the internet.
I hope this helps.
Neil. (v1230nm)
The cover that the plate is rivet on is gone thats why i can’t tell what type of engine it is.
What is Bryce?
Plus i don’t know what Type of dumper i have..
