BrianC86 wrote:Gavy wrote:Hi Brian, I have what looks to be the same model, with some of the same issues, I have managed to find a manual for a slightly different model but not my machine, I have a problem with my hand brake, the main brakes work fine but I have no hand brake, does your dumper have two levers sticking out of the front axle on the side, if you are lucky enough to find a manual can you let me know where. Gavin
Yes, I can see two levers facing me when the tipper is up. Applying the handbrake makes both levers pivot towards each other, the right hand lever moves more than the left if that helps?
I took a video of it but I'm unable to post it here unfortunately...
Brian, jack one wheel off the floor make sure the other wheels are chocked so it can't roll away, disconnect the lever on the side you have jacked up, spin the wheel by hand then move the lever as far as you can by hand, if the brake works you know it's just a case of adjustment, if not you need to look at where the lever enters the brake and see why it does not move the brakes themselves.
