Rear tyres
Discuss dumpers here
freddyuk
Been thanked: 7 times
Rear tyres
Post #1 by freddyuk » Sun Aug 05, 2018 9:05 am
If you are using standard treaded tyres on your small Winget or Thwaites dumper then get a set of three rib tractor front tyres (as should be on there as standard) and you will find the steering is transformed as in having power steering!! The difference is amazing. Using car tyres puts strain on the steering box as the friction is so high. I finally got my new three stud wheels and fitted new tractor tyres and it now steers so easily it is a joy. Tyres available on Ebay cheap enough.
cobbadog
Real name: John
Has thanked: 43 times
Been thanked: 23 times
Re: Rear tyres
Post #2 by cobbadog » Mon Aug 06, 2018 6:03 am
Very true Freddy. It is the reason why I just had to rebuild the steering peg in my steering box. TRI ribbed tyres are readily available through any tyre store as well as you have already said they are tractor tyres. The other thing to mention is not to use grease in your steering box as it is NOT suitable. It seperates when you operate the steering and never returns to make contact with the moving parts. I removed the old felt seal and replaced it with a normal oil seal and then filled the box with some good old SAE 140 grade oil. Heavy but good.
Has thanked: 472 times
Been thanked: 294 times
Re: Rear tyres
Post #3 by essexpete » Mon Aug 06, 2018 2:20 pm
Same on some older tractors as well.
Return to “Dumpers”
