PH2 oil level
womble3go
Real name: kevin
Been thanked: 4 times
PH2 oil level
Post #1 by womble3go » Mon Jul 02, 2018 12:16 am
HI,
Hoping that some one can help me I have a PH2 in my dumper on the dip stick there is only one mark on it is this the min level or max?
My PH1 has 2 marks on stick is easy to get right.
Thank you.
Re: PH2 oil level
Post #2 by Jeremy Rowland » Mon Jul 02, 2018 7:54 am
womble3go wrote:HI,
Thank you.
Kevin as a general rule if there is only one mark on the stick then it is the maximum mark hope that answers your question. :thumbup:
cobbadog
Has thanked: 302 times
Been thanked: 138 times
Re: PH2 oil level
Post #3 by cobbadog » Mon Jul 02, 2018 8:28 am
G'Day Kevin, If you have a manual on your engine then next oil change fill it up with the correct amount of oil less 1 litre or pint and insert the dip stick. This can then be permanently marked using a hacksaw and will be your minimum level. Then pour in the rest and it should be on you existing line if all goes well.
mechman
Real name: norman orrick
Has thanked: 144 times
Been thanked: 132 times
Re: PH2 oil level
Post #4 by mechman » Mon Jul 02, 2018 4:36 pm
Hi Kevin
My PH2 has 2 marks on the stick, may be yours could be off an oddball, can you put another mark on it?
Norm.
womble3go
Real name: kevin
Re: PH2 oil level
Post #5 by womble3go » Mon Jul 02, 2018 11:46 pm
Thank you for these reply's, I like the one of under filling then putting in the second mark, so will go for this.
Kevin.
Has thanked: 1295 times
Been thanked: 1111 times
Re: PH2 oil level
Post #6 by FOWLER MAN » Wed Jul 04, 2018 7:23 pm
The PH1 & 2 Should have the same dipstick.
The crank case casting of the PH1 is only a shorter version of the PH2 casting.
Everything else including the dipstick has the same dimension so just mark the one dipstick agsinst the other.
The part Nos of both sticks are the same.
Users browsing this forum: No registered users and 55 guests
