I'm after some advice on why a battery charge warning light is not working on my benford dumper with a ph 2 petter, I renewed the wiring and after much head scratching i cannot get the battery warning light to come on? I wired in an ammeter as per the ph2 wiring diagram and run a wire from the ignition switch to the light and another wire from the alternator marked "ind", I've checked the bulb and that is working, however the alternator has not been wired into anything for some time by the looks of it, I've researched on the net and the light should come on with the ignition and goes out once the alternator starts charging via the "exciter" wire, does the bulb have to be earthed as i tried the light in the holder direct of the battery terminals and it still didnt light up
Any thoughts really appreciated
Ian
