Nimbus Thwaite's dumper
Discuss dumpers here
Humber
Real name: Rick
Post #1 by Humber » Sun Oct 15, 2017 6:44 pm
Hi we have on our yard a small dumper. The clutch is not working rumour control says triumph herald brake shoes
How to adjust ....any tips ....it needs a bit of welding
Regard
Humb
Has thanked: 1873 times
Been thanked: 1692 times
Re: Nimbus Thwaite's dumper
Post #2 by Jeremy Rowland » Sun Oct 15, 2017 7:46 pm
Hi Rick and welcome :wave: somebody on here should be able to offer you some advice plus if you hunt through the dumper topic I'm sure this has been mentioned in the past so you may find your answer there too. :thumbup:
Humber
Real name: Rick
Post #3 by Humber » Mon Oct 16, 2017 9:22 am
Thanks it's just the system is no doubt quite simple the lack of documentation and parts is slowing down what should be an straightforward task. The clutch mechanism has about 30 odd years of rust had to grind off all bolts to access clutch thank you for message
longreach1976
Real name: John Welford
Post #4 by longreach1976 » Wed Oct 18, 2017 12:00 pm
Hi Humber I think your clutch /brake works with the brake in the on position and when you press the clutch you realease to change gear the brake linings will proberbly worn out you will have to have them relined
Tillywolves
Real name: Richard
Has thanked: 17 times
Been thanked: 29 times
Post #5 by Tillywolves » Sun Oct 29, 2017 12:31 am
there is an adjuster on the face of the clutch drum. And yes, I believe that the shoes are from a Herald.
Has thanked: 1295 times
Been thanked: 1111 times
Post #6 by FOWLER MAN » Sun Oct 29, 2017 1:06 pm
To adjust the clutch you have to get someone to hold the pedal right down and then tighten the adjuster on the back-plate all the way. Slack it back about two flats till the drum is just free and that's all that's to it. :thumbup:
I seem to remember that they used Triumph Herald shoes too, but it was a long time ago and I can't be sure. :think:
Return to “Dumpers”
