Old Benford info please
Been thanked: 684 times
Re: Old Benford info please
Post #11 by essexpete » Sat Aug 19, 2017 7:24 pm
Fred the gear box and steering box are phone to water ingress. I would think an EP 80/90 would be ok. If rhe steering is heavy check the box but also jack up and see if everything else is free.
Has thanked: 1295 times
Been thanked: 1111 times
Post #12 by FOWLER MAN » Tue Aug 22, 2017 1:18 am
May well help if you take a grease gun to the kingpins.
Jack it up to do this so the grease goes down through the thrust washers under the axle beam.
freddyuk
Been thanked: 8 times
Post #13 by freddyuk » Sun Oct 22, 2017 11:38 pm
After a false start I finally collected the dumper today. Did not fit the first trailer as the rear wheels are wider track than the front and I was given the rear track dimension.!
Adapted another trailer to take it backwards. It was a 5 hour journey.
It really is a heavy lump and much heavier than it looks. Managed to get it home with my Skoda as the 4X4 truck has a wobbly crankshaft pulley. No real dramas but a long line of Sunday drivers were not too happy behind me across to East Kent from East Sussex - sorry! I will not be towing it to Ireland with the Skoda as it is not fair..... on me or the Skoda.
It did start and drive after sitting since August so I have something to work on. I will go and find any markings tomorrow and do some images for positive ID from you experts.I will jet wash it and start the TLC it is so deserving of.
Hopefully I can get some maintenance info to make a start on keeping it going as it has some work to do before retiring.
freddyuk
Post #14 by freddyuk » Sat Oct 28, 2017 9:27 pm
I have images of the very faded engine plate. It is clearly a Petter engine. I have no idea what the numbers are but maybe someone does.
freddyuk
Post #15 by freddyuk » Fri Nov 03, 2017 5:05 pm
It is a Thwaites! I have scraped off some of the respray paint and I can make out Thwaites across the rear panel. Also there is "DIRECTOR...." can anyone ID the rest of it?
The throttle linkage is a mess and virtually hitting the flywheel housing so very little travel. It is all loose so I need info on setting this up correctly.
Should it be all the way forward (towards the front) when at rest?
Images have been rotated while uploading??
Mrsmackpaul
Real name: Paul Griffiths
Has thanked: 384 times
Been thanked: 256 times
Post #16 by Mrsmackpaul » Fri Nov 03, 2017 8:17 pm
I dunno if you know this or not Fred so disregard if you do already
When people out here talk wheel track we talk center of the tyre or track to center of the tyre or track, not the out side edge to out side edge, so old mate who supplied the measurements may well have been spot on
Good luck with the jigger
Ronan Keaveney
Real name: Ronan Keaveney
Been thanked: 11 times
Flag: Ireland
Post #17 by Ronan Keaveney » Sun Jun 30, 2019 10:23 pm
Hi Freddie, I recently bought a dumper identical to yours and could not identify what make it was as theres no Vin plate or chassis number anywhere.... where exactly have you found Thwaites on the panel ? If you get a chance could you post a few more pictures ... do you know if it's a Thwaites nimline ? Cheers... Ronan K...
Ronan Keaveney
Flag: Ireland
Post #18 by Ronan Keaveney » Sun Jun 30, 2019 10:29 pm
Ronan Keaveney
Flag: Ireland
Post #19 by Ronan Keaveney » Sun Jun 30, 2019 10:33 pm
This is my Dumper... I thought it was an old Benford but now that I see yours it must be a Thwaites... I'd like to find out the model and year of it if anyone can help... Thanks guys!!
cobbadog
Has thanked: 302 times
Been thanked: 138 times
Post #20 by cobbadog » Mon Jul 01, 2019 8:33 am
Sometimes you can get an idea of the date from the engine number. But that relies on the engine being the original and I done this on my Lister engine but I don't have any Petter details of engine build dates, hopefully someone here will.
Users browsing this forum: No registered users and 44 guests
