Hi Guys
can anyone tell me how to fit a new oil seal to the wheel end of my axel, do I just unbolt it and pull the half shaft out or will I need special tools,
Thwaites Alldrive axel oil leak
- Real name: Aj
- Been thanked: 4 times
Re: Thwaites Alldrive axel oil leak
Take the wheel off,secure the machine so it is higher on that side so the oil won't spill out,take out the half-shaft,remove the hub retaining nut/s,remove the hub,the seal is on the inside,no special tools required.
AJ
AJ
