Hi
Im going to tackle the centre pivot on my 1999 6 ton benford in the coming months.
Does anyone have an exploded view of this.?
Or better still a manual please.
Centre pivot
- Real name: John Turney
- Been thanked: 49 times
Re: Centre pivot
Hi,I might have a parts breakdown I shall have a look,I have the same job to do sometime had a look last year but left alone,the real issue with mine is excessive wear in the top link bar which locates under the steering column.
Cheers John
Cheers John
Re: Centre pivot
Thanks John
Mine is showing a loy of play in the lower section.
Rubbing the bolt heads of what looks like a retaining flange for spherical bearing or bush.
Re: Centre pivot
Hi Dan
Found something which might be of use? If you private message me your address I will copy and send to you
Cheers John
Cheers John
Re: Centre pivot
hi guys
i have the same job to do on a 1996 4 ton benford, any advice or diagrams would be greatly appreciated, cant even work out how to get it apart at the moment
- Has thanked: 302 times
Re: Centre pivot
I dropped the axle on my small 1500kg Benford Roughrider looking for wear and tare. The centre pivot pin and the bushes had very little wear but it would be a simple job to renew the bushes if required. You could use a hacksaw blade and make a cut along the bush and then tap it out or use the new bush to push the old one out but not recommended. There is a bearing shop near to me that has all sorts of bushes off the shelf so if I ever need to replace them I can buy one near the right size and machine it to size, instal and ream it to fit properly. Again if the pin had some wear I would either machine it undersize and make the bushes to suit.
Really not a hard job if yours is of the same principle a pin and some bushes. Tricky part is balancing the axle on a jack to lift it back up on your own. With help eay as.
