Hi Guys,
I've joined this forum in the hope that someone can help. We have a Thwaites Alldrive articulated 4X4 dumper, powerd by a 3 cylinder Lister electric start engine. We've always believed it to be a 7000 series, but when enquiring about gearbox parts from David Cornwallis, he reckons it's older than that as it is fitted with a Newage F4R2, 4 speed (Forward and reverse) gearbox. This is the type with 2 gear levers. It runs a Disc transmission brake. David sent me an exploded diagram of a box fitted to a Thwaites 6000Mk2, but this is not the gearbox as ours has a full size removable "lid" and runs a drum brake. When questioned, David said that it's "even older than he thought" and that he was unable to supply any parts. We are looking to find all bearings and seals in order to rebuild this box, but would consider a second hand box if one were available, as our has a couple of gears that are in poor condition. The plate on the lid of the box says Newage F4R2, s/no 3458, (there could be an extra figure at the start of the S/No as the plate is damaged). Embossed on the box lid is : F4R102. Has anyone got any suggestions where to try? Anyone have an exploded diagram of this box?
We are also looking to replace the "articulation" pivot pins/bearings. In order to identify the model of the dumper I will take some photos of the entire machine in the next few days. Now to try and upload photos of the gearbox casing!
Thwaites Alldrive/Newage F4R2 gearbox
- Has thanked: 1881 times
- Been thanked: 1695 times
Re: Thwaites Alldrive/Newage F4R2 gearbox
Hi Tim and welcome to CMN my suggestion would be that bearings and seals would be available from a local bearing/drives supplier; bearings are usually pretty much standard 'off the shelf' items as are seals, simply take your worn part along as a sample and where possible if the bearings/seals have disintegrated altogether take the bore size and the outer diameter size they should be able to fix you up with something.
- Real name: Paul Griffiths
- Has thanked: 384 times
- Been thanked: 256 times
Gudday Tim and welcome
Things are done a lot different out here in Australia we wouldnt even try the manufacturer for bearings and seals and would do what Jeremy suggests from the get go
Even if shafts are a bit worn you can have them built up for not a huge amount of money gears get a bit more costly does anybody wreck this type of thing were you are mabye just take the gear box along to a few different wreckers and see if you can match it up
Thanks guys, If the old bearings are identifiable that will be the plan, seals also, as long as they're not too stuffed to measure! However there is a pair of meshing gears that are badly worn as well as a worn shaft. Here in the middle of nowhere, (Central France), good machine shops are few and far between! Still hoping for someone with a box for needed gears, or a 2nd hand one!
