Hi, my first time on a forum such as this. I have just bought a Twaites Goliath dumper, I need a information, such as;
Is there a dumper or lorry etc. out there that uses the same master cylinders?
likewise re the steering ram, I could do with a good second hand ram.
Does any one have a workshop manual for one of these or at least for the Salisbury axles?
cheers
Nick
Twaites Goliath
Topic author - Posts: 5
- Real name: Nick
- Real name: Nick
- Has thanked: 1867 times
- Been thanked: 1688 times
Re: Twaites Goliath
Hi Nick and welcome to CMN I am sure that some body on here will be able to advise you.
- Has thanked: 849 times
- Been thanked: 680 times
Re: Twaites Goliath
That is a rarity! Does that have all wheel steering? I digress you could do worse than phoning Thwaites direct and asking for some technical help. They seem a very helpful bunch and they might have some archived info. The Ford engine is getting harder to source parts for (apparently)
- Real name: Nick
Re: Twaites Goliath
Yes it does have all wheel steering, and appears to have come from the factory as a "cabless" model. Engine is good, I've yet to sort out the gear levers which are sloppy. No noise from the axles, just horrible tin work!
- Real name: clive gray
- Has thanked: 174 times
- Been thanked: 242 times
Re: Twaites Goliath
My mate had one once and I used it a lot. Fantastic in their time and it had a cab! Good luck with it.
- Real name: Nick
