Hi fred
My engine is fitted with excess fuel position on as per your diagram, the problem I have is the speeder spring I beleive is slightly stretched hence when
the engine is cranked over the govener moves the pump from the excess fuel position to the run position too soon( reason for shim) . Different builds of st's are fitted with a cold start plunger for a oil/ derv mix on the inlet manifold, my engine is not hence for cold start crank engine 20 revolutions before dropping decompressor. Hope that that makes it a bit clearer.
-simon
Benford dumper with Lister ST2 compression pressures
Topic author - Posts: 13
- Real name: Richard
Re: Benford dumper with Lister ST2 compression pressures
Well....just to wrap this up, Yes, turning the cold start makes a big difference. Not quite good enough to hand start, but it starts easily on the starter. That is good enough for me!
Many thank to you all
Richard
Richard
- Real name: Denis Atkinson
Richard,
I have soft copy Lister Engine manual. If you would like a copy please pm me with your e mail address.
Regards
Denis
Regards
Denis
Thanks for the offer, Denis. I have a copy now!
R
R
Users browsing this forum: No registered users and 58 guests
