Benford dumper with Lister ST2 compression pressures
bobon66
Real name: simon warburton
Has thanked: 3 times
Re: Benford dumper with Lister ST2 compression pressures
Post #11 by bobon66 » Tue Mar 10, 2015 7:03 pm
Hi fred
My engine is fitted with excess fuel position on as per your diagram, the problem I have is the speeder spring I beleive is slightly stretched hence when
the engine is cranked over the govener moves the pump from the excess fuel position to the run position too soon( reason for shim) . Different builds of st's are fitted with a cold start plunger for a oil/ derv mix on the inlet manifold, my engine is not hence for cold start crank engine 20 revolutions before dropping decompressor. Hope that that makes it a bit clearer.
-simon
Richard Thorp
Real name: Richard
Post #12 by Richard Thorp » Sun Mar 15, 2015 2:58 pm
Well....just to wrap this up, Yes, turning the cold start makes a big difference. Not quite good enough to hand start, but it starts easily on the starter. That is good enough for me!
Many thank to you all
Richard
DADumper2
Real name: Denis Atkinson
Post #13 by DADumper2 » Tue Mar 17, 2015 2:34 pm
Richard,
I have soft copy Lister Engine manual. If you would like a copy please pm me with your e mail address.
Regards
Denis
Richard Thorp
Real name: Richard
Post #14 by Richard Thorp » Thu Mar 19, 2015 2:06 pm
Thanks for the offer, Denis. I have a copy now!
R
