Newage 40 gearbox
Topic author - Posts: 12
- Real name: Matt Jones
- Been thanked: 4 times
Newage 40 gearbox
Is it possible to swap over the drum clutch assembly onto a gearbox with the bell housing clutch, I've got a spare gearbox to go onto the aveling barford sd 06 I'm working on, the one that's in it is worn out.
- Real name: Ian Perrott
- Has thanked: 90 times
- Been thanked: 88 times
Re: Newage 40 gearbox
Hi Matt
I've just restored a Stothert & Pitt/ Aveling Barford SD06 and that's a different set up to the one i have. The gearbox I have in mine is tiny and to give you some idea of the size it has a bell housing on it with a 6" clutch of a hillman imp that is connected direct to the Lister LT1 engine
I've also done a newage 40 gearbox on a Benford 2000 dumper I have and the bell housing should part from the front of the newage 40 if you wanted to swap over gearboxes if I'm correct in what your thinking? I'll post some pics
That was the plan with it I'll hopefully manage to drop the gearbox that's on it out the clutch doesn't disengage as I found
out put my foot on the clutch and it did go into gear and shot forward off the block, I can't remember off hand when grandad converted it, after unsezing the engine it fired up first time .
Users browsing this forum: No registered users and 40 guests
