Centre pivot
Dan6
Real name: Dan
Flag: Ireland
Centre pivot
Post #1 by Dan6 » Wed Mar 29, 2017 4:16 pm
Im going to tackle the centre pivot on my 1999 6 ton benford in the coming months.
Does anyone have an exploded view of this.?
Or better still a manual please.
taurus MK1
Real name: John Turney
Been thanked: 48 times
Re: Centre pivot
Post #2 by taurus MK1 » Thu Mar 30, 2017 10:25 pm
Hi,I might have a parts breakdown I shall have a look,I have the same job to do sometime had a look last year but left alone,the real issue with mine is excessive wear in the top link bar which locates under the steering column.
Cheers John :rockon:
Dan6
Real name: Dan
Flag: Ireland
Re: Centre pivot
Post #3 by Dan6 » Sat Apr 01, 2017 10:00 pm
Thanks John
Mine is showing a loy of play in the lower section.
Rubbing the bolt heads of what looks like a retaining flange for spherical bearing or bush.
taurus MK1
Re: Centre pivot
Post #4 by taurus MK1 » Mon Apr 03, 2017 8:59 pm
Hi Dan
Found something which might be of use? If you private message me your address I will copy and send to you
Cheers John
Dan6
Real name: Dan
Flag: Ireland
Re: Centre pivot
Post #5 by Dan6 » Tue Apr 04, 2017 7:39 pm
Pm sent
Stever
Real name: steve royce
Re: Centre pivot
Post #6 by Stever » Sat Feb 23, 2019 9:16 pm
hi guys
i have the same job to do on a 1996 4 ton benford, any advice or diagrams would be greatly appreciated, cant even work out how to get it apart at the moment
cobbadog
Has thanked: 112 times
Been thanked: 58 times
Re: Centre pivot
Post #7 by cobbadog » Sun Feb 24, 2019 6:08 am
I dropped the axle on my small 1500kg Benford Roughrider looking for wear and tare. The centre pivot pin and the bushes had very little wear but it would be a simple job to renew the bushes if required. You could use a hacksaw blade and make a cut along the bush and then tap it out or use the new bush to push the old one out but not recommended. There is a bearing shop near to me that has all sorts of bushes off the shelf so if I ever need to replace them I can buy one near the right size and machine it to size, instal and ream it to fit properly. Again if the pin had some wear I would either machine it undersize and make the bushes to suit.
Really not a hard job if yours is of the same principle a pin and some bushes. Tricky part is balancing the axle on a jack to lift it back up on your own. With help eay as.
