40M2S and 40M2T interchangeable?
GlenM
Real name: Glen Morgan
Post #1 by GlenM » Sat Mar 10, 2018 2:03 am
As per the subject, my dumper has a 40M2S gearbox that needs an overhaul (again). Would a 40M2T gearbox fit? It's a Thwaties Alldrive 6000 with a PH2 engine.
Thanks.
Glen.
Whitlock 505
Real name: Ian Perrott
Has thanked: 50 times
Been thanked: 41 times
Re: 40M2S and 40M2T interchangeable?
Post #2 by Whitlock 505 » Sun Mar 11, 2018 9:50 pm
Glen
I've just overhauled a 40m newage gearbox and when my son ordered the parts he was told there was very little difference between the variants, I think the "T" denotes a transfer box for 4 wheel drive applications, the castings are the same
Ian
GlenM
Post #3 by GlenM » Mon Mar 12, 2018 1:00 am
Ian,
Thanks for your reply. It does sound probable that there are few differences. My dumper is 4wd and it has the S box with a separate transfer box.
I did e-mail PRM yesterday to ask, so will see if they reply.
Glen.
Whitlock 505
Post #4 by Whitlock 505 » Mon Mar 12, 2018 3:07 pm
Glen
Hopefully PRM will be able to help but they told me that the 40M box had not been made for years, I found plant & engineering services of Exeter very good and they know they're stuff about dumpers and gearboxes.
Have you got a pic of the box in question?
Cheers
Ian
GlenM
Post #5 by GlenM » Thu Mar 15, 2018 12:39 am
PRM were extremely helpful, they said that the only differences between the two could be bellhousing, output flange and gear-lever. They offered to check which of the three it might be, by full serial numbers but the guy selling T 'box on e-bay pulled it, despite me having a bid already on it!
We have already re-built this one a couple of times because it keeps destroying the needle roller bearings on the front of the layshaft. Not sure why. I do now have a solid brass bush from another spares 'box, which fits in place of the bearings, so that might be worth a try.
I use the dumper for work, so I need to get a spare 'box to fit, then the original can be repaired and kept in reserve.
I don't think I have a photo of the 'box.
Whitlock 505
Post #6 by Whitlock 505 » Sat Mar 17, 2018 11:16 pm
Hi Glen
That's what I replaced the needle bearing with a brass one, after rebuilding the casing, had to make sure there was an oil journal around the bearing for lubrication
Ian
GlenM
Post #7 by GlenM » Sun Mar 18, 2018 11:45 pm
Ian,
That's interesting. Where did you get the brass one from? I guess there is an oil feed for the needle bearing anyway. The old brass one has an oil hole through it to an oil groove.
The T 'box is back on e-bay again, so I have agreed a price and will hopefully be picking it up tomorrow/Tuesday.
B-Man
Real name: Andy
Been thanked: 10 times
Post #8 by B-Man » Mon Mar 19, 2018 10:04 am
Hello
If its the needle bearing I think youre on about (part number 0561404) it changes to a brass bush now part number 0561404B. We fit these to the 40M2B124 gearbox fitted to old Benford 2 Ton Dumpers. I've attached a gearbox breakdown of the Benfords Gearbox so you can check where it goes. They can be obtained from a company called Plant and Engineering in Exeter phone number 01392 882220. I'm sure there give you dimensions etc to make sure its the correct part your after.
Andy
