Volvo ec 210 fuel problem
Topic author - Posts: 38
- Real name: Jon Umpleby
- Been thanked: 7 times
Hi all . Started my Volvo 210 the other day at about 17 below freezing with no problem after it had been stood for three weeks.But after a few minutes at low idle it stoped.The rubber seal on the fuel filter housing had gone hard,this had only been changed about two months ago and was a genuine volvo part.Must have been the very low temperatures to cause this.What a nightmare to get it started again when it had filled the fuel system with air so it would be worth checking if any one has got a volvo been stood in this cold weather.Cheers Jon
- Real name: wullie g
- Been thanked: 14 times
Re: Volvo ec 210 fuel problem
hi jon as working mine at -10 last week with no problems but have been warned by volvo fitters never to let fuel system run dry they have all told me it is a nightmare to get it started again
- Real name: Julian
- Been thanked: 13 times
Jon Umpleby wrote:Hi all . Started my Volvo 210 the other day at about 17 below freezing with no problem after it had been stood for three weeks.But after a few minutes at low idle it stoped.The rubber seal on the fuel filter housing had gone hard,this had only been changed about two months ago and was a genuine volvo part.Must have been the very low temperatures to cause this.What a nightmare to get it started again when it had filled the fuel system with air so it would be worth checking if any one has got a volvo been stood in this cold weather.Cheers Jon
Are you sure that you didn't suffer fuel waxing? I had it on all my tractors and minidigger because my diesel is still summer diesel. I'm not sure how a rubber seal can go hard in only two months - sounds a bit of a long shot to me.....
Julian.
- Real name: dave lynch
- Has thanked: 38 times
- Been thanked: 15 times
had similar problem but with Komatsu pc130 @Cumbernauld,error code for fuel filter freezing kept coming on last week,diesel looked a bit waxy too,should be winter stuff tho?maybe machinery going the same way as the population,not used to cold weather and getting softer lol?
Users browsing this forum: No registered users and 70 guests
