What do the pedals do Jeremy?
Engine probably a 590e
Hymac Excavators
Re: Hymac Excavators
essexpete wrote:What do the pedals do Jeremy?
Pete from memory the two lower ones are connected to the two center levers to enable foot control, the one at the far side of the cab is the brake pedal, they did not have automatic brakes, you have to pump up the pedal and close a gate valve to hold the brakes on.
Andy80 wrote:So loveley to see that restored Hymac 480 How did they find parts to restore it? The flat tracks locks brand new, where did they get dem?
Andy the worn tracks were all re-bushed with new pins that took the wear out of them; the trouble is that a former owner had removed two track pads from each side to remove the wear so the machine needed four new track pads, these were machined from solid steel blocks and I must say they have made a first class job of them.
Andy80 wrote:Would be wery interesting to see pictures of that restoration, expecially the restoration of the tracks
Sadly there are no photographs of how the tracks were repaired but if you have Tony Flints number then give him a call he is very helpful. I have covered an article for this in one of the forthcoming Classic Plant & Machinery magazines.
Topic author - Posts: 5422
- Real name: Nick Drew
- Has thanked: 437 times
- Been thanked: 208 times
Jeremy Rowland wrote:essexpete wrote:That looks like another set of skills to drive it! What engine Jeremy?
Yes Pete I got a go in this machine at the Chipping Steam Fair before its restoration but you get used to the controls they're 'push-pull' levers, she's got the earlier 6 cylinder Ford engine in her the one where the injection pump is driven off a shaft from the timing casing, I forget the model number now.
What a stunning restoration mate, who owns this and is he/she an approachable person ?
Nick Drew wrote:Jeremy Rowland wrote:essexpete wrote:That looks like another set of skills to drive it! What engine Jeremy?
Nick I'll pm or phone you.
- Been thanked: 686 times
