changing hydraulic oil on 1982 3cx
Discuss excavators here
Whitecab jockey
Real name: Mitch parsons
Has thanked: 2 times
Post #1 by Whitecab jockey » Sun Jan 15, 2023 10:10 pm
Hi everybody,
Need some advice regarding maintenance of the hydraulics on my 3cx. I am looking to change the hydraulic oil clean the filter. can i crowd the bucket to enable me to get under the cx then open the drain plug or is it best to leave 4:1 on ground. ive got two side entry circle plates on either side of the hydraulic tank is where i gain access to filter ? first time attempting this job so not sure what i will find are there any other filters which should be changed or cleaned.
many thanks
mitch
gecko.cx
Real name: ian
Has thanked: 126 times
Been thanked: 114 times
Re: changing hydraulic oil on 1982 3cx
Post #2 by gecko.cx » Mon Jan 16, 2023 12:34 am
Welcome Mitch
Start with the closest manual you can find (mine is sufficiently different not to be helpful)
app.php/dl_ext/?cat=5
If the oil is long overdue, there will be a lot of sludge in the bottom of the tank you'll want to mop out as well as changing the filters
Has thanked: 1873 times
Been thanked: 1692 times
Post #3 by Jeremy Rowland » Thu Jan 19, 2023 10:04 pm
Hi Mitch welcome to the site :wave: there should be plenty of help to be had. :thumbup:
Return to “Excavators”
