can anyone help with hydraulic rams for ec15 mini digger
looking for lengths of the cylinder open centre and retracted centre dimensions cylinder outside dimension and rod dimensions
i have a boom and dipper arm that i want to retro fit on an old power fab digger
volvo ec15
Topic author - Posts: 8
- Real name: duncan mitchell
- Site Admin
- Has thanked: 232 times
- Been thanked: 143 times
Re: volvo ec15
Hello,
I asked on Maskinisten and the member bangt could answer the cylinder outside dimension and rod dimensions for a EC15B:
cylinder outside dimension 70mm
rod dimension: 35mm
rod dimension: 35mm
Some resources:
How-To
How-To
Re: volvo ec15
703/3 is 500mm closed centre with 300 mm stroke? ext 800 mm
703/4 is 600mm closed centre with 400mm stroke ext 1mtr
703/450 is 650 closed centre with 450mm stroke ext 1.1 mtr ext
Re: volvo ec15
Holger wrote:A approx 65
B approx 60
C approx 50
did you check the closed centre and ext centre lengths for me
- Real name: ian
- Has thanked: 126 times
- Been thanked: 114 times
Re: volvo ec15
Bigdunkpowerfab1200 wrote:looking for lengths of the cylinder open centre and retracted centre dimensions cylinder outside dimension and rod dimensions
The open and closed lengths "you" need will be determined by the cylinder mount on your kingpost carriage.
The original cylinder dimensions may not be appropriate.
Also, you need to compare the system pressures between the two machines to see if the original piston diameter will give the appropriate force.
