Hi guys, just bought a pel job eb25 which is the same as a volvo ec25 i believe, I have lots of flashing lights on the instrument panel and am afraid to use it til I find out what they mean. Can anyone tell me what each lamp/symbol means please.
instrument panel warning lights.
Topic author - Posts: 2
Re: instrument panel warning lights.
Just an update, I have found that the bottom left is hydraulic oil temperature, which when on permanently I guess means oil temp is too high, but mine is flashing from cold, could this mean that the level is too low??? not sure but I believe that flashing is a a low level indicator? I guess also that this refers to hydraulic oil.
Check the oil level or perhaps a malfunction on the sender/sensor.
Have you sorted the top row?
The one next to the hyd temp looks hydraulic related.
- Has thanked: 1887 times
- Been thanked: 1701 times
Hi Hank; first thing to do is check all of your oil and coolant levels then at least you should do no damage to your machine, like Pete says there could be a sensor malfunction. The top set of lights I am only guessing here, left to right; battery charging light, engine oil level, engine temperature warning light, engine cooling restriction light and cold start light, please bear in mind that these are assumptions but I hope it points you in the right direction.
