Jcb 801.4 perkins 100.30
Discuss excavators here
Nathanrogerbailey
Real name: Nathan Bailey
Has thanked: 1 time
Been thanked: 1 time
Re: Jcb 801.4 perkins 100.30
Post #11 by Nathanrogerbailey » Sun Feb 26, 2017 8:45 pm
Ive put a new battery on
Had jump leads on it as well running off a running 4x4
No fuel at injectors when cracking the engine
Has thanked: 1873 times
Been thanked: 1692 times
Post #12 by Jeremy Rowland » Sun Feb 26, 2017 9:15 pm
Okay while I am not sure of the setup on these machines get yourself a small can of derv and try it on a gravity feed, so a piece of pipe straight from the can of derv to the fuel injection pump and then try it.
Mrsmackpaul
Real name: Paul Griffiths
Has thanked: 384 times
Been thanked: 256 times
Post #13 by Mrsmackpaul » Sun Feb 26, 2017 9:29 pm
Your rack or slide is stuck inside the injector pump
I dunno anything about these small motors but Im pretty sure from all I have read here thats the problem
Any Perkins motor I have ever owned are really good starters
So I assume you motor has a solenoid to stop the engine try giving it a few good whacks as they can stick some times
The next thing you need to put up here is a good photo of the injector pump so that we can see what the set up is from there and try to advise from there
Nathanrogerbailey
Has thanked: 1 time
Post #14 by Nathanrogerbailey » Sun Feb 26, 2017 10:28 pm
Tried the gravity fed way still no luck. Tried solenoid out as well.
Here is pick of injector pump
Nathanrogerbailey
Has thanked: 1 time
Post #15 by Nathanrogerbailey » Sun Feb 26, 2017 10:30 pm
Nathanrogerbailey
Has thanked: 1 time
Post #16 by Nathanrogerbailey » Sun Feb 26, 2017 10:31 pm
Thats the fuel injector pump. The engine is perkins 103.10
Post #17 by Jeremy Rowland » Sun Feb 26, 2017 10:39 pm
Nathan can you pump clean air free fuel to the main injection pump without any bubbles of air in it; and if you can is there a bleed screw on the fuel injection pump?
Nathanrogerbailey
Has thanked: 1 time
Post #18 by Nathanrogerbailey » Sun Feb 26, 2017 10:46 pm
Yep bleed the filter before it enters the injection pump. Bleed banjo screw above injector pump.
However there is no bleed screws on the actual injector.
I did takenthe pipes off as u can see and fuel just about dribbles out. No pressure at all
Post #19 by Jeremy Rowland » Sun Feb 26, 2017 11:01 pm
Nathan I have not seen this type of injection pump before but there must be a bleed screw on it somewhere? Can you get any pictures of the side of the fuel injection pump?
These things can be a pig to bleed; however from what you have been saying in this thread I suspect that you may have additional issues with either the engine or the pump?
Nathanrogerbailey
Has thanked: 1 time
Post #20 by Nathanrogerbailey » Sun Feb 26, 2017 11:09 pm
Read somewhere that these cassette injector pumps have no bleed screw. It just plugs straight into the engine.
If i remove it will i mess the timing out?? Just 4 bolts hold it in place
Return to “Excavators”
