Hi im new to the forum any body out there that can help me i have a hanix mini digger with a 3cyl diesel in it i was using it then it dies on me i have taken seat out and found out it just turns over slowly or clicks on key but if you bridge terminals on starter it spins fast
I have found a melted black and white wire under seat and it gets hot while cranking i got it running on brake cleaner and bridging starter and it works fine
Any ideas ???
help with my mini digger
Topic author - Posts: 1
- Real name: stuart buss
- Been thanked: 192 times
Re: help with my mini digger
Are you saying it will only run on brake cleaner but not on its own diesel? I would guess those wires are feeding the electric fuel pump and/or the fuel cut off valve on the injector pump and are shorting out.Could also be from the key switch to the starter.Shorted wire gives less current to the starter solenoid and thus clicking or slow cranking.
