Hymac 580C slew motor seals
- Real name: Håkan
- Has thanked: 46 times
- Been thanked: 26 times
Re: Hymac 580C slew motor seals
Thanks for the videos Matias. I recall i have seen them before. I think i saw them on the Swedish sister sight Maskinisten. In the number 3 video it really seems slow in the slew. Did it come suddenly or over time?
- Has thanked: 1887 times
- Been thanked: 1701 times
Hi Matias, I have spoken with Tony Flint and he says that he thinks the problem with your machine is not the Staffa motor but the hydraulic pump is the problem when a machine slows down when it gets warm that is the case. Hope that helps, I have also pm'd you some other info that you may need.
- Real name: Matias
- Been thanked: 4 times
Jeremy Rowland wrote:Hi Matias, I have spoken with Tony Flint and he says that he thinks the problem with your machine is not the Staffa motor but the hydraulic pump is the problem when a machine slows down when it gets warm that is the case. Hope that helps, I have also pm'd you some other info that you may need.
Thank you!!
Andy80 wrote:Thanks for the videos Matias. I recall i have seen them before. I think i saw them on the Swedish sister sight Maskinisten. In the number 3 video it really seems slow in the slew. Did it come suddenly or over time?
The problem came with time. Maybe it's like jeremy says pump wear, I don't know .. I think the problem is the slew
One segment of the triple inline hydraulic pump supplies the spool valve that feeds the slew and the auxiliary circuits so that would be the reason why the pump would be the issue the other two parts of the pump may not be as badly worn thus not affecting other operations. I would tend to trust what Tony Flint says on this but it's not too much trouble to get the pressures checked and this would confirm the issue.
- Real name: Håkan
Is the other hydraulic functions working at normal speed?
Do you have an extra boost on the dipper arm? If you have, it shares pump with the slew and should be sluggish to if the third pump is worn. Jeremy please correct me if i'm wrong
Andy80 wrote:Is the other hydraulic functions working at normal speed?
Andy you are correct try using the dipper (or boom depends which way it is piped) with the auxiliary function when the machine is warm; if it is slow using only that function and on the slew then you know it is the pump.
