Hi Graham,
I work for WP DONAGHY contracting it is my dads company we are a small company we do some sub contract work for core utility solutions (mainly electricity duct and cable laying) and do some drain and water pipe repairs for various companys we have 3 hi roof transit vans and a scania 6 wheeler grab truck that we recently bought from a utility company in yorkshire we hire our mini excavators in at the moment we have 2 jcb 801.8s brand new
I have been driving the scania for the past month as the grab driver left to work for pn daly
We have been trying to get some work from docwras for a while now as they are in partnership with scottish water doing development work on new housing and industrial sites but not got any through yet maybe soon they are suppose to be good payers when you are a subbie
more bursts
- Real name: craig donaghy
Topic author - Posts: 759
- Real name: graham
Re: more bursts
been out today on another burst ,but this time i did not have to get dirty
i am covering standby for one of the grab drivers
got to drive a new iveco 8 wheeler with an auto box not sure on that it seems a bit slow changing and setting off especially if your at a busy roundabout
anyway the main was 6" cast iron and is rotten it had about a metre long split
and at some point it had also been lined with pu resin
i think this is the third burst in a month in this street so its down for renewal
knowing less and less about more and more until pretty soon i will know almost nothing about practically everything
- Real name: tim
- Has thanked: 226 times
- Been thanked: 135 times
Re: more bursts
Hi Graham,a couple of the Docwra drivers have said the auto Ivecos are very slow pulling away. Atlas Bulk Carriers bought some automatic Daf 8 wheelers 2 or 3 tears back and the divers said they were bad as well. We have 2 auto box Volvos at work a grab and a tipper, i have driven the tipper and moved the grab in the yard and though i hate to speak too well of Volvo's -being a Scania man, the Volvos are very quick away,and you have the option of changing gears manually as well. Tim
- Real name: graham
Re: more bursts
hi tim this is the first auto truck i have driven ,it had the option to change gear manually on the right hand stalk ,but i still put my left hand out for a gearstick when approaching roundabouts etc
cheers graham
cheers graham
- Real name: graham
Re: more bursts
another burst on the 8" pvc last night i got called about 8.30 got the job done and took the digger back to our job in time for work today will be early to bed tonight
pictures are a bit crap , taken with my phone in the dark
cheers graham
cheers graham
- Real name: graham
Re: more bursts
got a phone call this morning to go to a burst on a 8" asbestos main in the verge not a bad job as the main had been turned off and most of the water had drained away
the pipe had split from a previous repair to a colar
we tryed a new style coupling out ,and it worked well
all backfilled and home by 4 pm
cheers graham
cheers graham
- Real name: IBH
- Has thanked: 12 times
- Been thanked: 87 times
Re: more bursts
An Asbestos main? What it that exactly? I'm guessing its a type of asbestos concrete its made from similar to the corrugated roofing sheets of old?
Containing asbestos do they create H&S issues when it comes to removing (e.g cutting) and disposing of them?
Sorry for all the questions Graham, but just inquisitive with things like this.
Re: more bursts
Hi Graham,
Is that the fittings that go over old collars on 1 side and the new pipe on the other
Craig
Craig
- Real name: graham
Re: more bursts
craigdonaghy wrote:Hi Graham,
Craig
Craig the coupling fits any material, it is a just for joining straight pipe not over collars ,it has a gripping ring and will not move once tightened
we used a similar type in London for capping mains and it will not move ,no need for acrows / thrust blocks
i will try and get a picture of inside the coupling
IBH
we double bag all the pipe seal them up and they go for special disposal ,we cut the pipe with reed cutters and have a supply of water ,so no dust
cheers graham
Return to “Workplaces/Job reports”
Users browsing this forum: No registered users and 44 guests
