TD 6 is now home with the rest of the machines.Hopefully it will be completed in time for next years vintage show season.
TD6 home at last
Topic author - Posts: 6393
Re: TD6 home at last
Looks like you have got your work cut out then Martyn; look forward to seeing the finished machine.
It going to be an interesting project Jeremy as parts for these are hard to get hold of.Should be easier than a tracked loader though .Will spend the winter months searching for bits.Its a solid tractor.
Hi Martyn,
Good to see it home.
We could have saved a lot of energy swinging the thing if you 'd decided on using the crane sooner.
Are you feeling fit for another swing at it Fred Now to get the motor sorted
I spent 2 Autumns as a student discing and rolling with BTD6. I did not know it was on the farm until it was dragged out of the back of an obscure shed. It had a nasty shed on it which meant you were hot as well as dusty. I cooked the gearbox on it because I had not realised the oil was low, but as I had not 'got it ready' I did not really get the blame. The next year shed was removed so cold and damp! Christ it was boring discing a 90 acre field with a 10ft set of discs, twice.
- Real name: wayne akerman
- Has thanked: 50 times
- Been thanked: 30 times
Looks to be quite a find, pto, do you know if that was a rare item. While some wear draw bar looks in good shape. While in air being unloaded tracks don't look to have lots of sag, doesn't seem to be much wear on grousers. Do you know how long it may have set before you picked up. Looks like a fun project, hope the shop roof stays blue as you work on this project.
This machines last outing was at our vintage show in 2002,so its been stood in more or less the same spot in my mates yard for 10 years.I have owned it for two,just getting around to restoring it The machine originally cam from Wiltshire.Its last workout was pulling a four furrow plough which it did with ease.The pto output shaft is bent,the machine it was driving damaged the fuel tank when the shaft flew off.
B100 LOADER wrote:Are you feeling fit for another swing at it Fred Now to get the motor sorted
Always ready to help martyn
I hadn't noticed the PTO when I was down there with you.
I bought a brand new PTO unit for mine. Still available in 1959 for £ 145 - 00.
Thanks Fred, next job is to get the starter sorted.How are you getting on with Barry's TD18 ?
