Just got myself a small sand blaster off Ebay. Coupled it up to my Hydrovane and tested it on one of my projects.Seems to work fine.
I am also looking at another machine to join the others.Its a dozer.Waiting to get time off to go and see it.
Sand blaster
Topic author - Posts: 6393
- Real name: Philip Pyle
Re: Sand blaster
Hello martyn
I need to buy/hire a sand blaster for my JCB 3C restoration project.
What site unti do you have and how much sand does it take to blast a typical wheeled excavator?
Cheers
philip
Cheers
philip
Re: Sand blaster
Hello Philip
It cost £60 new off Ebay its a 10 Gallon blaster,uses kiln dried sand, air pressure 100 psi 40cfm. Uses around 250kg of sand per hour.Had to modify the end as ceramic nozzle too small for the job.Used 3/8 bsp steel pipe connection and it works fine.My hydrovane is rated at 75 cfm but the compressor is over 30 years old so would be down on output.
I would use a air sander and a blaster for the type of job you have got.It used to take me around three days to do a JCB from start to finnish.Preparation is to key to a good job.I have also done a job using nitromors and a sander with good results.
Don my BTD6 using this method.Much harder to do a tracked loader than a JCB
Last edited by martyn williams on Fri Feb 22, 2008 12:45 am, edited 1 time in total.
- Real name: John Gaunt
Re: Sand blaster
I like the 'before' picture, Martyn. I used to drive one of these. It was fantastic in terms of power loading compacted soil from a heap. Only problem was getting on and off between loads (I was working alone). Brings back some pleasant memories though !
Re: Sand blaster
John, this machine came from your part of the world.Got it from Jonathan Mintz of Tractor Co, Smalburgh.
Re: Sand blaster
thats a really good finnish. i'm looking to get a sand blaster myself, one of the reps brought round the sealey summer promotions catalogue this week. does anyone think this will be any good? i'm looking to remove thick paint of plant for re-sprays mainly.
see:
http://www.sealey.co.uk/PLPageBuilder.a ... onID=53907
cheers
si25
see:
cheers
si25
"toy soldier"
Re: Sand blaster
It is similar to the one I have.They are not bad for the price,as long as you can get hold of good sand or shot. I have used Nitromores for thick paint.A bit expensive but does the job and a lot quieter
Re: Sand blaster
B100 LOADER wrote:Just got myself a small sand blaster off Ebay. Coupled it up to my Hydrovane and tested it on one of my projects.Seems to work fine.
just new to this did i read on another site that you knew where there is a jcb 110 for sale its took me a little while to find a way to get in touch with you
thanks leo
Re: Sand blaster
I know for one but it needs a lot of money thrown at it to get it right.
Cheers
Cheers
