Fordson Major V8 conversion Cooling issues.
clonbernedave
Real name: David Chippendale
Flag: Ireland
Post #1 by clonbernedave » Thu Oct 26, 2017 2:49 pm
I have fitted a Perkins 540 V8 into my Fordson major and would like some advice on cooling .Please can anyone help .I have been told that the standard rad out of the major will cope is that true .I am not planning to pull with the tractor just road runs and vintage shows .If anyone knows of a company that will manufacture a rad if need be please again please let me know .
Thanks Dave
hair bear
Real name: Rob
Has thanked: 194 times
Been thanked: 281 times
Re: Fordson Major V8 conversion Cooling issues.
Post #2 by hair bear » Thu Oct 26, 2017 6:24 pm
Hi and welcome.
From memory the standard rad is the full width/height of the bonnet so unless you're thinking of one that is thicker I'm not sure what else will fit. The only things I can suggest is make sure the fan is well shrouded to give a ducted effect, maybe tweak the fan blades to give a bit more pull, or see if there's enough room in the front cowling to fit a Kenlowe type fan for some extra airflow. Just be sure if you go down the Kenlowe route that both fans are propelling the air in the same direction!
diggerjones
Real name: dylan jones
Has thanked: 40 times
Been thanked: 33 times
Post #3 by diggerjones » Thu Oct 26, 2017 9:13 pm
Just put some electric fans on it. I am not an expert. But I was slightly involved in tractor pulling in the 80's and I'm sure with the major my mate had. 6 cylinder turbo with electric fans
Has thanked: 1873 times
Been thanked: 1692 times
Post #4 by Jeremy Rowland » Fri Oct 27, 2017 7:31 am
Hi Dave and welcome to CMN :wave: I would have thought from what you have said that the standard radiator should be able to cope as the tractor is not being put to any hard work; I would give it a few short test runs around one of your fields and see how it copes, please bear in mind that I don't know if your tractor is fitted with a temp gauge, that's the way I would tackle this issue.
Has thanked: 853 times
Been thanked: 684 times
Post #5 by essexpete » Fri Oct 27, 2017 7:35 am
Am I right in thinking that you can have 2 or 4 blades fans on the Major?
Post #6 by Jeremy Rowland » Fri Oct 27, 2017 1:41 pm
essexpete wrote:Am I right in thinking that you can have 2 or 4 blades fans on the Major?
Pete it will depend upon the hole centres that are drilled and tapped in the engines water pump mounting as to what fan can be fitted.
Has thanked: 1295 times
Been thanked: 1111 times
Post #7 by FOWLER MAN » Sun Oct 29, 2017 1:39 am
Hi Dave,
It's usual to use the standard Fordson radiator for this conversion together with the Perkins six blade fan.
You will however need to fabricate a new radiator shroud to accommodate the Perkins fan as in the pics. below. This arrangement seems to cope OK.
Return to “Projects”
