JCB Crawler Excavator 208 1983-86 model
Steelfab
Real name: Julian Carder
Been thanked: 59 times
Re: JCB Crawler Excavator 208 1983-86 model
Post #11 by Steelfab » Fri Feb 12, 2016 2:02 am
JCB Special Hydraulic fluid is ISO 46 oil
Explo
Real name: Charlie
Has thanked: 12 times
Been thanked: 15 times
Post #12 by Explo » Fri Feb 12, 2016 12:00 pm
Thanks Steelfab.
C.
Explo
Real name: Charlie
Post #13 by Explo » Mon Feb 15, 2016 1:19 pm
Very productive day spent in the workshop on Saturday. Bucket, dipper and boom ram seals done so no more leaks. Then moved onto the track which needed to loose a link. By god the pins were tight so made up a jig to push them out. Was still just on the limit of the 10 ton ram.
Next job was to reset the track tension ram and replace the top roller bearings. Then re-attach the track and tension correctly.
While I was on a roll I thought I'd look at the other side roller bearing. What the frig!!!!!! There was no bearing and the track had been cutting grooves in it!
Only solution for now, weld up the grooves, turn best i can on the lathe, new bearings and hope it works! Ok it's not perfect but hey, it works for now. I call that Charlie-6 JCB-0. Not a bad day :-)
Has thanked: 1165 times
Been thanked: 979 times
Post #14 by Jeremy Rowland » Mon Feb 15, 2016 2:59 pm
Nice one Charlie :claphands: having access to a lathe and welding equipment all helps with resto jobs, plus the skills too and not forgetting the little helper. :D
Mrsmackpaul
Real name: Paul Griffiths
Has thanked: 382 times
Been thanked: 253 times
Post #15 by Mrsmackpaul » Mon Feb 15, 2016 9:45 pm
thats the go steady steady dont get to much on the go like I do and end up with nothing finished
nothing wrong with welding up a roller there is some special grade of rod thats meant to be used according to the experts Im not real sure what it is but I reckon what ever you used will be just fine
Track pins always take a lot of pushing to get out well done done mate :thumbup:
happy little worker still on the job
great stuff and keep it coming
Return to “Projects”
