Its here, we used a telehandler and stropped the front axle to the forks/framehead then the telehandler lifted it slightly and provided the steering with some single side footbrake action to help steer from the jcb itself.
My homemade ram props, I split some heavy steel tube I had knocking about along the tube so it could be split and placed around the hard chrome section of the ram, and left room to put a wrap of old innertube under it, then clamped the two halves together with some intercooler clamps.
I was really glad I did it this way as at one point the loader arms lifted up, and normal ram props might be been dislodged. There was also a pinch bar lying right across the machine and strapped into place in case a clamp came adrift as a failsafe.
This shot shows what happened to the roof. The stabilizer leg that was down when it rolled wont retract fully with the strap so its possibly bent. The wheelarch has a split both sides where its flexed when it was on its back possibly also I noticed.
Also its leaking fluid from underneath, possibly from the hydrachassis, the steering wheel is shaped like a pretzel and other stuff.
It was a tidy looking machine pre-accident (I used to see it about and my kids would give me grief for not having painted mine as nice yet) and would be possible to reassemble it, fix/repair/replace all the bent & broken parts but it would be a big job and I already have one to finally make progress on fixing. The loader arms are in far far better condition than mine, it has a straight unbent main grille with period correct lights intact still, a hydraulic compartment door etc. But wow, is that cab a pain to get in and out of in comparison to a 3c3. Especially without the floorplates down.
For the 3c3, I got some new core plugs and plugged up the leaks in the repair on the "scrap" head, and I'm waiting for a parcel with a complete set of new valve guides to arrive from the UK for it. When that turns up, provided its not -4 like today, I'll put the head back on and run up the 3c3, if its fixed it even better and I can use it to move the parts into better places when I take them off the 3c2 before taking it apart further, if it still uses water it has to be the liner and it can come out as planned and I'll just have to figure ways to manhandle all the lumps with winches/pulleys and strops as usual.
