carnage 3ciii
MrF
Real name: Phil P
Been thanked: 5 times
Flag: France
Re: carnage 3ciii
Post #41 by MrF » Sat May 16, 2020 1:08 pm
Finally I fixed some more stuff so I might as well dig this up from the past, but also to shame myself in how long its taken me to do some of the jobs (though to be fair, I was out of action for 2 years growing new bits during it after a big accident in my landrover 101...)
As elsewhere on the board I extracted #3 after a really low compression reading, but reposting here to just keep it in one place now.
Original URL: http://gallery.pipandphil.com/Vehicles/workshop/jcbpiston1.jpg
Liner to match
Original URL: http://gallery.pipandphil.com/Vehicles/workshop/jcbliner.jpg
New liner in, after some shennanigans with cap marking being altered
Original URL: http://gallery.pipandphil.com/Vehicles/workshop/jcb_newpot.jpg
Head back on, painted the rocker cover and I've bought a replacement rocker cover cap because one of the legs has fell off the old one. I know its the wrong shade of yellow for the machine, bu its better than rust.
Original URL: http://gallery.pipandphil.com/Vehicles/workshop/jcb_headon.jpg
I took off the rad at the suggestion of someone here and backflushed it, and got all the grunge off the bottom with the steamer, then pressure tested it as I have always been suspicious of the top tank as its damaged by some idiot in the past standing on it. And it was leaking between the filler neck and radiator top tank, and the filler neck itself was twisted. So I bought a replacement neck off ebay and sweated the old neck off.
Original URL: http://gallery.pipandphil.com/Vehicles/workshop/jcb_rad_oldneck.jpg
Its oval too, you can just make this out.
Original URL: http://gallery.pipandphil.com/Vehicles/workshop/jcb_rad_oldneck2.jpg
Soldered new neck in, and holding at 5psi. Yes my "testing" rig is bits of old inner tube wrapped round the spigots and hose clipped to stop leakage, but it works and it was free. I painted it matt black after this to keep corrosion at bay and its back in the machine now.
Original URL: http://gallery.pipandphil.com/Vehicles/workshop/jcb_rad_testing.jpg
I picked up the correct 3c canister air filter off ebay to replace the transit pancake housing it had on it, and bead blasted it and painted it and put new filters in it, but no photo of that. I can't find anyone selling a intake hose to connect it the manifold so I'll have to make something to suit.
Besides that, I replaced the tacho drive box, and ordered a new tacho cable, vicary have them in stock for the 3c iii if anyone is searching still, and some other seller on ebay who wanted double the price for postage etc. Now waiting for more stuff to arrive & I have next week off to get some more stuff done if it turns up.
Has thanked: 1382 times
Been thanked: 1201 times
Re: carnage 3ciii
Post #42 by Jeremy Rowland » Sat May 16, 2020 11:00 pm
Nice work Phil well done. :claphands: :thumbup:
diggerjones
Real name: dylan jones
Has thanked: 19 times
Been thanked: 22 times
Re: carnage 3ciii
Post #43 by diggerjones » Mon May 18, 2020 10:46 pm
Well done
MrF
Real name: Phil P
Flag: France
Re: carnage 3ciii
Post #44 by MrF » Sun May 24, 2020 12:47 am
Well, its together. Air filter I have worked out is the wrong one for my machine, it should have the one with the filter connection at the rear, but despite the strange shape fabricated elbow (welded together from some intercooler pipework bends) and two flexible sections, it seems to be ok. The exhaust is homemade and not at all fitting the appearance, but its better than a rotten original with holes in and it makes the gas go in the right direction and removes enough of the noise. Another thing which is bothering me is the fan shround has no lip, its effectively just a flat plate with a fan shaped hole in it and I know that kills fan efficiency, did they have a shroud lip which fitted outside the fan? was it part of the mesh belt cover affair (thats missing also). Also the front "bonnet" for the section in front of the radiator is missing also, I think that wont help cooling so I'll see about making one.
Original URL: http://gallery.pipandphil.com/Vehicles/workshop/jcb_engine_together.jpg
It now has throttle and engine stop brackets to replace the mess I got it with after squinting at the sole picture in one of the parts books.
I made up two substantial L brackets to screw onto the end of the dpa pump where the original part mounted, and turned up blocks with threaded posts on them & tapped the throttle cable one to suit its threads (bizarrely m10 outer irrc, and 7/16 AF inner!) and used nylocks underneath, so the blocks can pivot to stay aligned to the pulling forces rather than ragging the cable on the bracket sides. And it now has a proper stop lever in the cab. And it goes back on its own. Luxury. I probably should have used thinner steel but it works.
Original URL: http://gallery.pipandphil.com/Vehicles/workshop/jcb_throttlekillbracket.jpg
More fettling on the electrics again & machine refused to start off the key, the problem was traced to the "new" ignition switch fitted being intermittent & the neutral starter inhibitor switch on the top of the gearbox being bad. I now have that jumpered with a link, but I'll see about changing it before it tries to run me over when starting it one day. The ignition keyswitch I've ordered a genuine nos lucas one instead of generic rubbish.
Running it up proper, I had to back off the low rpm stop screw on the top of the pump before it would idle slow enough for my liking (600rpm) so I see that as a good sign as it must have been carrying the bad cylinder since before the pump was rebuilt when I first got it, but I warmed it up and now 3 of 4 injector sleeves leak water. Which although not disturbed perhaps my radiator no longer leaking is now putting pressure on other weak spots and its just been there all along. I will find a suitable rawl bolt and expand them/replace them if it doesn't. And I put my foot on one of the front wheel rims slipping off a step ladder and tore a valve out of the tube, so now I have to put a new tube in too so that'll be sunday's private gym workout with some tyre levers in the yard.
Finally the tacho now works, but is really lazy. I have a plan involving some thin lubricant if it doesn't free up in a few more minutes running. But, I'm pleased its even bothering to wave the needle. That's progress.
Return to “Projects”
