This is what happens when you send a truck into the steel works for a couple of weeks to cover some repairs....
Was used carrying hot material as you can see by the discolor in the skip sides.
The after pics are after a session on the steam cleaner by the way
Time for another shotblast and paint.
SB
771D Before and after.
Topic author - Posts: 1247
- Real name: Stu Bickley
- Has thanked: 70 times
- Been thanked: 116 times
- Has thanked: 1887 times
- Been thanked: 1701 times
Re: 771D Before and after.
Joes1989 wrote:Surely the hot material would weaken the strenth of the steel....no?
That would depend on several factors but the tipper body may be made out of a material like Hardox in which case the heat would have no effect.
If the truck is going into these applications on a permanant basis the body is lined with Hardox, in this case it was only in for a couple of weeks and wasnt suppose to be hauling hot material, they even denied it when it came back but the evidence speaks for itself!
SB
SB
- Real name: Jason Fisher
Sounds like the case of " yeah we greased it regularly" when you tell them all the grease points are dry! Some transformation, did it get other work than a freshen up
Sorry, the pics posted in the wrong order, the respray was BEFORE it went in for a couple o weeks work......
Needed another after........
SB
SB
Return to “Haulers/Dump Trucks”
