just purchased a pedestrian roller, not a clue what it is. but I can start it and it goes forward and reverse. having problems getting the clutch to engage /disengage for the vibrator
any help as to what it is . As all the manufactures plates have either been painted over or have fallen off with corosion
roller identification help
Topic author - Posts: 11
- Real name: rob robertson
its never as simple as it first seemed
Smalley mini digger 430 lister lpws3
Liner rough rider lr2 diesel
- Real name: Ian Fletcher
- Has thanked: 534 times
- Been thanked: 148 times
Re: roller identification help
Take the side cover off ( right side viewed fron the handle ) and see if anything is sticking on the linkage or clutch.
found a few pictures of the S& P roller its close but not quite the same
more photo's to aid identification
See that you have taken the side cover off to expose the clutch.
You now need to start the roller and operate the vibrator clutch to see if it is engauged.It could be that it will need stripping and cleaning and inspect the plates for wear. Also check the operating linkage for wear and adjustment. Also remove the vibrator drive belt and check that the vibrator shaft bearings are ok.
I have done a lot of work on these rollers as the firm I use to work for were agents for S & P and Atkinson ( Greens) also Benford
think it might be closest to a stothert&pitt v37, it preceded the w71
- Real name: Julian
- Been thanked: 13 times
Hi Rob, quick question - is the roller for a job or is it just to play about with as a toy? Just wondering if they are collectable or not!
Julian.
Julian.
