Hi All,
Quiz time again.
I found these dozer pics. on the net recently. Anyone know what these dozers were and who built them.
Whats this bit of history ????
Topic author - Posts: 2358
Re: Whats this bit of history ????
Last one obviously has tank/bren type suspension. Did Loyd not have this set up?
Hello Fred
Looks like it has tank running gear similar to the Vigors, prototype from Vickers ?
- Real name: craig
- Has thanked: 156 times
- Been thanked: 374 times
Looks like Sherman Tank running gear , are these the ones Vickers built for the Tanganykan Groundnut scheme ?
- Real name: Angus Shapland
- Been thanked: 72 times
- Real name: craig
Its a ' Shervick' made by Vickers for the Ground Nut Scheme and reportedly useless compared to the CAT's
In the third pic you can just make this name out on side of hood.
Hello all,
Thanks for the replies, and yes, it does look a bit Russian.
You are right Craig it is a SHERVICK, built by Vickers using reclaimed Sherman tank components.
They were not a converted tank as such but built as a tractor from the ground up. they were powered by a single GM 6/71 engine whereas I bileive the tank had two.
Some 400 were built circa 1948/9 and many were sent to Africa to the illfated Ground Nut Scheme, where as you say, they proved to be less than reliable.
The one in the Photographs however, is seen working in Holland.
Vickers started the development of the VR180 in 1950 but they didn't appear on the market till March 1952.
- Real name: Deas Plant.
- Been thanked: 9 times
Hi, FowlerMan.
Int'restin'. It's been quite a while since I heard or saw anything on this post-WW2 failure. Here is a photo of a Shervick and another of a Morpac rock drill based on a Sherman Tank.
Thanks for the photos and the information.
- Real name: Mr. Scholz
- Has thanked: 3 times
- Been thanked: 10 times
There were some Sherman conversions built by Letourneau. First is a simple crane-magnet setup for scrap yard use at his steel mill. Probably to avoid punctured tires.
And this one was called Tree-Crusher-Tender I believe. They used its dozer blade and powerful winch to recover bogged Junglecrushers in swampy terrain.
The last one is not based on a Sherman, maybe it was a Highspeedtractor, but this cable-backhoe-thing sure looks impressive!
Cheers, Max
Cheers, Max
- Real name: Paul Griffiths
- Has thanked: 384 times
- Been thanked: 256 times
Letourneau sure built a lot weird stuff I guess this happens when you have big heaps of cash and big ideas and dreams
thanks for sharing
thanks for sharing
Users browsing this forum: Bing [Bot] and 8 guests
