Some sheduled maintenance
Discuss dozers here
68a
Real name: nicky
Has thanked: 82 times
Been thanked: 209 times
Re: Some sheduled maintenance
Post #481 by 68a » Sat Jan 28, 2017 3:30 pm
You have hit the nail on the head Jeremy.
I can't see it changing anytime soon either
68a
Real name: nicky
Post #482 by 68a » Sat Jan 28, 2017 3:45 pm
Saw the D8R on Monday ripping things up.Stll looks clean as it hadn't rained in the last 3 weeks.
The D8H is working into the dark for the last 3 weeks,but rain may stop playing soon.
Fuel pressure was starting to back off abit on Thursday on the 8H,so I fitted new ones on Friday afternoon after work..
It finishes at 3.3ppm on Friday's.
Backed it's arse up abit to help with the fuel flow as it was after 3.30 and low on diesal
Bowser won't come until 7am Monday,so I figured I could use a little gravity.
68a
Real name: nicky
Post #483 by 68a » Sun Feb 19, 2017 12:20 pm
Still busy with 2 of the D8's.
The D8R trashed the implement pump on Tuesday night,this was it's first breakdown as such and I was away on the other D8,so between Tony Coates on the phone,Young Ian on the spanners,and great staff at Finnings (who knew what I needed better than I did) the d8 was running again on Thursday after having it's tank cleaned out and new Cat pump fitted.It has clean up filters fitted for 12 hours,then oil drained again,then normal filters fitted and replaced every couple of shifts until the look clean after being cut open.
The other D8 was serviced on Saturday and I ran around it with the big bar to pull a few loose idler bolts and a blade trunnion up.
68a
Real name: nicky
Post #484 by 68a » Sun Feb 19, 2017 12:30 pm
A few pics of progress
Has thanked: 1188 times
Been thanked: 1011 times
Post #485 by Jeremy Rowland » Sun Feb 19, 2017 5:00 pm
All go then Nicky :thumbup: remember me to TC next time you speak to him. :thumbup:
68a
Real name: nicky
Post #486 by 68a » Sun Mar 05, 2017 9:49 am
Bit of servicing and replacing clean up filters from the hyd pump problem.
Bought one of those vacume hold grease ends.Really handy for the eq bar fittings.
Other D8 rained off now.
Could be a while.
It rained hard just after I took this pic of the 68A
68a
Real name: nicky
Post #487 by 68a » Sat Apr 15, 2017 10:32 am
Got one of the tractor and boxes out
68a
Real name: nicky
Post #488 by 68a » Sat Apr 15, 2017 10:36 am
New center edge fitted seriously helps in loading the box faster,and much easier on the tractor and fuel bill
68a
Real name: nicky
Post #489 by 68a » Sat Apr 15, 2017 10:40 am
Quicker than loading a dumptruck
68a
Real name: nicky
Post #490 by 68a » Sat Apr 15, 2017 10:44 am
Getting the bad muck out first and spreading over the tip to let it dry out.
Return to “Dozers”
