dozer with backhoe
Discuss dozers here
ruston bucyrus
Real name: 450lc
dozer with backhoe
Post #1 by ruston bucyrus » Sat Dec 26, 2009 10:39 pm
can you post a pic of a tracked tractor with a backhoe evan a track loader
sean
Real name: Sean
Re: dozer with backhoe
Post #2 by sean » Sat Dec 26, 2009 10:55 pm
Look in track loaders section in my thread 'IH powershift pic swap scheme'
sean :)
d4c24a
Real name: graham
Post #3 by d4c24a » Sat Dec 26, 2009 10:59 pm
ruston bucyrus wrote:can you post a pic of a tracked tractor with a backhoe evan a track loader
:thumbup:
knowing less and less about more and more until pretty soon i will know almost nothing about practically everything
martyn williams
Real name: MARTYN WILLIAMS
Has thanked: 296 times
Been thanked: 356 times
Post #4 by martyn williams » Sat Dec 26, 2009 11:14 pm
Here is a M F and a I H machine for you
Martyn Henley
Real name: martyn henley
Has thanked: 38 times
Been thanked: 48 times
Post #5 by Martyn Henley » Sat Dec 26, 2009 11:26 pm
Heres another
:thumbup:
Martyn Henley
Post #6 by Martyn Henley » Sun Dec 27, 2009 11:57 am
Here is a couple of dozers with backhoes ..
This JCB Hydra digger is on the back of a county crawler with a blade.
And this one is mounted on the back of a Track Marshall
Both photos were taken in 1957.
Martyn :thumbup:
martyn williams
Post #7 by martyn williams » Sun Dec 27, 2009 12:06 pm
The JCB back acters must have put a fair bit of strain on the final drives of the crawlers.The wainroy ones were much lighter than the JCB ones.
When we worked the MF 200 and 300 we used to take them off when not required.
Gavin Phillips
Real name: Gavin
Been thanked: 12 times
Contact:
Post #8 by Gavin Phillips » Fri Jan 01, 2010 6:37 pm
Seen a few track loader & backhoe combinations on eBay over the last few years. Even a couple of Cat 931/931B's.
I sometimes grab the images if they are unusual enough.
Here's an Aveling-Marshall 1100 track loader fitted with backhoe attachment. Previously, Track-Marshall 1100 had the controlls for the backacter mounted outside the cab so the operator couldn't work both loader & backhoe controls from under cover.
As far as a bulldozer with backhoe...there was such an option for the Cat D3 and possibly for the later D3B as well. Track-Marshall also offered one for their Model 55 hydraulic bulldozer. Can't recall ever seeing pictures of one though.
Look out that window, Eden isn't burning. Its burnt.
alan627b
Real name: Alan Hynes
Contact:
Post #9 by alan627b » Fri Jan 08, 2010 2:08 am
Did a quick Google search on the Hyster Hystaway..all sorts of attachments, crane, cablehoe, dragline.
hope this helps!
Google search results...
http://images.google.com/images?hl=en&s ... a=N&tab=wi
Retro Grading, We Do Modern Jobs with Antique Machinery
chris73
Real name: chris lewis
Has thanked: 5 times
Post #10 by chris73 » Wed Jan 27, 2010 8:15 pm
Return to “Dozers”
