dozer with backhoe
Topic author - Posts: 112
- Real name: 450lc
Re: dozer with backhoe
Look in track loaders section in my thread 'IH powershift pic swap scheme'
sean
sean
- Real name: graham
ruston bucyrus wrote:can you post a pic of a tracked tractor with a backhoe evan a track loader
Here is a M F and a I H machine for you
- Real name: martyn henley
- Has thanked: 38 times
- Been thanked: 50 times
Heres another
Here is a couple of dozers with backhoes ..
This JCB Hydra digger is on the back of a county crawler with a blade.
And this one is mounted on the back of a Track Marshall
Both photos were taken in 1957.
The JCB back acters must have put a fair bit of strain on the final drives of the crawlers.The wainroy ones were much lighter than the JCB ones.
When we worked the MF 200 and 300 we used to take them off when not required.
- Real name: Gavin
- Been thanked: 12 times
Seen a few track loader & backhoe combinations on eBay over the last few years. Even a couple of Cat 931/931B's.
I sometimes grab the images if they are unusual enough.
Here's an Aveling-Marshall 1100 track loader fitted with backhoe attachment. Previously, Track-Marshall 1100 had the controlls for the backacter mounted outside the cab so the operator couldn't work both loader & backhoe controls from under cover.
As far as a bulldozer with backhoe...there was such an option for the Cat D3 and possibly for the later D3B as well. Track-Marshall also offered one for their Model 55 hydraulic bulldozer. Can't recall ever seeing pictures of one though.
- Real name: Alan Hynes
Did a quick Google search on the Hyster Hystaway..all sorts of attachments, crane, cablehoe, dragline.
hope this helps!
Google search results...
http://images.google.com/images?hl=en&s ... a=N&tab=wi
hope this helps!
Retro Grading, We Do Modern Jobs with Antique Machinery
