Trying to what model Fiat these track plates fit
Re: Trying to what model Fiat these track plates fit
Overall dimensions are 400mm x 178mm, large holes are 17.5mm, small holes are 12.7mm in diameter. I have been told, These fit models that came out around 1960. These could be used on some later models (not many around) if the holes were drilled out to suit a 9/16" (14.75mm) bolt. I am keen to confirm info and would appreciate all help thanx.
- Real name: Jim
- Has thanked: 5 times
- Been thanked: 20 times
Nice OEM plates.
Try your local Berco agent.The 100x56 spacings are the relevant holes.
GW Tractors,here in Oz,might know their parent crawler.
The MF300 (9 ton) comes up at 108 x 56.That's the closest I can find.
MF used Fiat chains for their smaller crawlers.
I reckon they'll be off a Fiat or Landini Ag tractor...about 6-8 ton size.
The Fiat crawlers had a good reputation here..the 555 & 605 etc were good Ag dozers.Also the AT 70/70C were well-liked.
Jim
Jim
