its got a Letourneau blade double drum PCU Im taking that off and making it into a hydraulic A&T blade
a few years ago it ran a bit low on water and well when I poured water in I cracked a head so due to other stuff going on in life I have only got around to it now
anyway have been collecting parts for it for a few years now and I will need it for a big job (or at least a big job for me in june july & august so time to get cracking
I only learnt about these pre-combustion chamber in recent times and told that that was the most likely thing so I thought whip them out an with any luck all my problems will be solved yeah right
so some eager person in the past had taken to the big buts that hold the injectors in with a cold chisel I had a huge drama getting the injectors out one of them had almost no nut left so I cut it out with the gas axe a bit rough I know another came out still stuck in the pre-combustion chamber so I finally got these parts out they all looked good to me except the crook cut in half injector
URL of the original image: http://i1370.photobucket.com/albums/ag265/MrsMackPaul/IMG_0240_zpsavpm5tu2.jpg
the took some swinging off a bar to get them to move
URL of the original image: http://i1370.photobucket.com/albums/ag265/MrsMackPaul/IMG_0237_zpsh8eze4tu.jpg
URL of the original image: http://i1370.photobucket.com/albums/ag265/MrsMackPaul/IMG_0226_zpsbtrsp20l.jpg
so I thought I better rip the head off before I attack it with the gas axe thes pre combustion chambers looked fine to my untrained eye so out with wire brush and look what I found
URL of the original image: http://i1370.photobucket.com/albums/ag265/MrsMackPaul/IMG_0249_zpsnot3y4ut.jpg
URL of the original image: http://i1370.photobucket.com/albums/ag265/MrsMackPaul/IMG_0262_zps48hadkns.jpg
so I found real bad rust scale in the water manifold and two thermostats were missing parts so my theory is the cracked head was blowing back thru the head and loosened all the rust
URL of the original image: http://i1370.photobucket.com/albums/ag265/MrsMackPaul/IMG_0225_zpstxc0ffcc.jpg
URL of the original image: http://i1370.photobucket.com/albums/ag265/MrsMackPaul/IMG_0223_zpsnhvvyuwy.jpg
URL of the original image: http://i1370.photobucket.com/albums/ag265/MrsMackPaul/IMG_0221_zpstnr0gt2o.jpg
not sure what this pipe does but not much at the moment
URL of the original image: http://i1370.photobucket.com/albums/ag265/MrsMackPaul/IMG_0217_zpsw7sgipzm.jpg
URL of the original image: http://i1370.photobucket.com/albums/ag265/MrsMackPaul/IMG_0216_zpsgzyuaigp.jpg
so I decided to pull the other head and check it out its spotless so I feel my theory is fairly sound about all the rust scale
I have found a welding place in Townsville who feel they can weld up the head up ok they have been recomended from a few places
so I will run thead up tomorrow and see what they say
