Powerfab 1000X
Topic author - Posts: 11
- Real name: Steven Robert Morris
- Has thanked: 4 times
Powerfab 1000X
Hi, does anyone have any parts for the Powerfab 1000X similar to the PFL Terrier. I'm looking for the aluminium block which attaches to the drive motors. Thanks
- Has thanked: 1883 times
- Been thanked: 1696 times
Re: Powerfab 1000X
Bobisok wrote:Hi, does anyone have any parts for the Powerfab 1000X similar to the PFL Terrier. I'm looking for the aluminium block which attaches to the drive motors. Thanks
While I don't know what this block looks like, how easy would it be to get one fabricated?
Re: Powerfab 1000X
Ahh right, I thought it was part of a coupling you were after but it is part of a valve block, what exactly is wrong with the one you have?
Re: Powerfab 1000X
The corrosion is very bad due to when I got the machine under the protection plates it was full of mud etc it had been there for some time. The aluminium in areas must be wafer thin near the internal drillings. I'm thinking if possible it would be better to change first rather than it leak on a job.
I think they are fitted to change the direction of flow. the leak - off/ return to tank line also goes to it.
Sorry about the delay with this reply, the notification was in my SPAM box
Re: Powerfab 1000X
You can see the state of the corrosion, the Allen bolt thread Is clearly visable.
The leak off pipe doesn't actually go to the valve block, instead it goes to the motor body.
Re: Powerfab 1000X
Rexroth parts should be available from a hydraulics dealer, I would just type in the identification number into Google and see what comes up and take it from there. Let us know how you get on.
