Latest.
Replaced alternator every thing was fine, when I put everything back together the light was back on.....
Took it apart found I broke the L wire connectiion on connector block side on loom when refitting obviously its was brittle.
Anyone got any ideas where to buy a new replacement connector ?
Tried JCB but you have to buy a new loom!!!!!!
Almost there...........
JCB 801 boiling batteries
Topic author - Posts: 15
- Real name: Rom Swiokla
- Real name: Paul Griffiths
- Has thanked: 384 times
- Been thanked: 256 times
Re: JCB 801 boiling batteries
I gather your alternator looks like one of these sought of with the two spade connectors at right angles if so you can just cut both the wires of and put two spade connector plugs on
My alternator has 3 connections , but if icannot find the correct plug I will take up your suggestion
Many thanks Paul for the idea
Managed to find replacement female connectors on ebay for a couple of pounds and replaced them in old plug . things are now sorted and no boiling battery as voltage now does not exceed 14.6v when charging....
Job done another happy customer lol
good to hear it's all sorted and you get back to living the dream
Sorry for late conclusion.
The alternator replaced cured the problem thank you all for the helpful advice.
