Thought Id better start my own thread for this but does anyone know where I can get a service kit and parts for a 90d as I have oil coming out with the air, also anyone got any starting instructions and maintance stuff for them.
cheers john
hydrovane 90d
Re: hydrovane 90d
I have done a fair bit on the Hydrovanes.
Service kits are on Ebay ,type in Hydrovane.
Starting is straight forward,from cold.Go to preheat position on the switch,older machines are fitted with a thermostart. You will se a lever on the compressor air end, ( on compressor air end body same side as start key ) pull this lever up. Go to start engine after pre heat.turn engine over till it fires,release lever on air end casing.Run for a few minutes to warm through then couple up air line and use.
Oil in air is a sign that separators need servicing,but can also be wrong grade of oil.
The air end on an 90D Hydrovane is a CWD 66.oil is Shell rotella SX 30 takes 5 ltrs
Topic author - Posts: 14
Re: hydrovane 90d
thanks for the reply but cant find any kits for a cwd66 I will contact the firms on there and see if they do them.
cheers john
cheers john
Re: hydrovane 90d
Try these
ThoriteDirect web customer support:
Email: online@thorite.co.uk
Tel: 0800 034 1811
Fax: 0800 136918
For general sales and all other enquiries:
Email: sales@thorite.co.uk
Tel: 0800 034 5850
Fax: 0800 136918
Tel: 0800 034 1811
Fax: 0800 136918
Tel: 0800 034 5850
Fax: 0800 136918
Re: hydrovane 90d
Head Office
Claybrook Drive
Washford Industrial Estate
Redditch
Worcestershire
B98 0DS
United Kingdom
Telephone: +44 (0) 1527 525522
Fax: +44 (0) 1527 521140
E-mail: hydrovane.red@gardnerdenver.com
Maybe this will help
Claybrook Drive
Redditch
Worcestershire
B98 0DS
United Kingdom
Re: hydrovane 90d
thanks for your help martyn but still know joy they say they are to old and I wont get any parts from compair for it. any other ideas
cheers john
cheers john
Re: hydrovane 90d
Contact one of the Ebay sellers,compressor man,I think he goes under. I will ask around.There is a firm near Bristol that may have old Hydrovane stock. They did have a Hydrovane 90 D for parts there.
Keynsham Plant Services
Unit 7A / Burnett Business Pk
Gypsy Lane
Bristol
Avon BS31 2ED
Gypsy Lane
Bristol
Avon BS31 2ED
Re: hydrovane 90d
Well just like to say thanks for the help so far. I finally got round to get it striped down and got the new parts for the seperator (AAcompressorkits). next problem is getting it back together as I need to press the end cap down to be able to get the the tube with the lifting eye in. has anyone done this if so what did you use to press it down?
cheers john
cheers john
Re: hydrovane 90d
http://www.ebay.co.uk/itm/Hydrovane-90DSS-Service-Repair-Parts-List-Manual-Perkins-4-Cylinder-Diesel-on-CD-/160892756622?pt=UK_Air_Tools_and_Compressors&hash=item2575f4a28e
This is the super silence later version but the air end is the same
